Originally posted by mi2nc I figured out the problem. Whan I put the battery cover on the receiver something must be shorting out as it doesn't with the cover on, but works like a gem with it off. Anyone have ideas how to fix this?
..or something might be getting disconnected as the cover lodges it out off connection?
Put the cover on and off slowly and see what it is hitting.
If it is hitting a wire, then try to move that wire with your finger with the cover off while testing it.
..or a transistor or a diode is being dislodged out off connection too?
Try to peep inside as you put the cover on and see what it is actually hitting and maybe depressing.
