Code4code... - we had some very recent threads with basically the exact same questions - so you may find the search facility helpflu.
Generalle the use of UV filters is open to debate (and hotly debated), because their filtering properties are of low value, unless you photograph under excessive UV light (at more than 2500m height, under extremely dry and sunny conditions with snow/ice around, sometimes at the sea shore under really bright blue skies).
It is clear, that ANY aditional filter in front of the photographic lens will degrade image quality. This is a physical necessity. It is NOT so clear, if a really high quality filter degrades the image quality VISIBLY. In my experience a first rate filter does not degrade image quality visibly, if used wisely:
- remove filters, when shooting directly into a light source (sun, bright lamps etc.), as the filter will produce additional reflections, ghosting, flaring - even if it has a fancy multi-coating
- remove filters indoors, unless you need one for colour conversion (which you don't with a DSLR)
- remove the filters for night shots, as (see first line) any filter will increase flaring and ghosting.
- ALWAYS use a good (aka the right) lens hood, with a filter, to minimize additional reflections/flare.
Then there are still applications for a UV filter as a lens protector:
- in very windy conditions and sandy/dusty environments
- near the sea with salt spray around
- when shooting dirt track and similar events
- when small children are around, whose natural curiosity might lead them to probe your lens with their fingers (yes, I had that with completely strange kids), which just clutched a messy ice cone...
Skylight filters have a slight pinkish tint, to make images (in film days) taken under overcast skies a bit warmer and more pleasing. I never quite understood, why anybody would use a Skylight as a protective filter, when the colourless UV is available.
Polarizers are helpful to reduce unwanted reflections on non-metallic surfaces (car paint, windows, foilage etc.). This gives better colour saturation and better colour contrast. As Polarizers remove part of the light (the part that matches the polarization level of the filter), they actually reduce overall brightness contrast, especially as the bright sky usually contains the highest amount of polarized light. Brightness contrast and colour contrast are two different things.
Even in digital days I find two other kinds of filters very helpful, as they cannot fully or only with extreme time-consuming computer sessions imitated during post-processing:
1. the Neutral Density (ND) filters. These simply block part of the light and do not influence the quality of the light (colour or contrast). This is extremely helpful, when shooting in bright light, but wanting a wider open aperture to reduce depth of field. Sometimes you may also simply want a much longer expsoure time, which you cannot achieve without additional ND filters. I personally use them mostly when shooting portraits under bright light, to keep my aperture wide open.
2. the Graduated Grey filter (ND Grad), to reduce excessive contrast between very bright parts of an image (usually the sky, sometimes sand on a beach or snow) and the less bright rest of the image. There upper part is grey and gradually the density of the grey vanishes, until the lower part is completely clear. The idea of the graduation is, that the transition between the grey and the clear part of the filter should not be visible in the image.
GRADs should be used in a filter holder (Cokin, HiTech, Lee etc.), which allows to rotate the filter to the desired angle and to shift the filter up and down in the filter holder to place the transition as you prefer.
With layers and masking you can to some degree imitate the action of NDs and Grads in Photoshop, but I rather use the filter (cost: 1 minute or so), then sitting half an hour per image on the screen. Especially blurring the background in a portrait, because the aperture was stopped down to much, is a pain somewhere and suddenly mounting a ND filter really looks so easy...
Ben
