Originally posted by dkittle Gooshin, you can use the onboard flash of a K10D or a K20D to trigger (optically) AF360 and AF540 flashes. Range is REALLY limited outdoors/in bright light.
I bought a cheap ($35) P-TTL cable from Henry's with the idea of cutting it and splicing in wires to run to my flashes, but never carried through with the idea. I found that I prefered metering with my handheld light meter and using the flashes in manual mode to trying to get P-TTL working. And HSS is really only good for fill, it's not really powerful enough to overpower full sunlight by a couple of stops - if that is what you are looking to do.
Radio Poppers (radiopoppers.com) support both Nikon and Canon TTL systems, pocket wizards do Canon now and Nikon soon. I've not heard of any radio trigger that supports P-TTL, unfortunately.
But try wireless with your onboard flash. I did a shoot at a chapel in UofT and used my onboard as a controller only (did not contribute to the exposure) to fire an AF540 used to fill a mom/daughter sitting in a windowsill - the results were pretty good.
hey Don,
i tried activitaing my 540 with the pop up flash in a home setting at night, and did not like the results, although this may be different during the day.
at this point this is my only option since i dont have any of the other things.
i have a shoot coming up where there will be lots of sunlight coming in through a window, so i'm trying of figuring out ways to fill in the shadows while capturing whats outside, all the while using F2.8 or something.
