Originally posted by soccerjoe5 I forgot to add though that while arca swiss plates are quite costly at about $40-60 a piece
I make my own out of a 1 1/2 inch by 1/8 inch flat aluminum stock. I simply cut two pieces of the flat stock to the right length, file down the edges to the right angle, then metal epoxy the two pieces together to make the plate. I use a triangle file to finish the groves. To provide a lip, I simply metal epoxy an end piece on to the plate. It takes about an hour per plate to make, not counting the 24 hours for the metal epoxy to set.
I bought a 30 inch length of the stock for about US $9. I have a US $5 plastic miter box, a US $10 hack saw, a US $10 set of files, two US $4 small C clamps, and a US $30 cordless drill. I have these for many years now, so the tools aren't just for this. The plates are ugly, but I don't really care.
This ugly monstrosity is a tripod mount I made for a Version I Tokina 80-400mm.
Hard to see, but I made the plate under this macro rail. The macro rail is a $49 ebay rail, with a $40 Kirk 1.75 inch 1/4-20 mount QR plate. For a around $100, I have the ugly cousin of the
Kirk focus rail.
I spent the money for Kirk L-bracket as I wouldn't try to make a plate for the camera.
Thank you
Russell
