Originally posted by stoge Do you need a filter with multicoating on a filter, if your lens already has one? If the filter has a multicoating, will it reduce flare?
A good multi coating is especially important with circular polarizers, as these have two glasses (with the pol foil sandwhiched in between), which makes four glass-air surfaces. As you lose nearly 4% of light due to reflection on an uncoated glass-air surface, you would loose nearly 16% of light just though reflection with an uncoated CPL!
And these 16% are usually not just reflected back into the landscape but somewhere else and to a good part right into the lens and will cause ghosting and flaring and reduced contrast.
Ben
