Originally posted by bingsean Hello, I used to have the lowepro slingshot 200 AW bag for my K10D+grip+DA*50-135, however as I got the DA*16-50mm and DA*300mm lens, I found I can not put all in one bag, especially the DA*300mm lens. Could you give me some recommendations? How about slingshot 300 AW?
If you rotate the dividers in the AW 200 Sling you can carry up to an eight inch lens off the camera. There was a photo of the K10D with grip, with the bag set up this way, where the grip was tucked into the deeper left side. This leaves the two right pockets exposed for longer lenses.
You might also take a look at this
post by
rfortson
Thank you
Russell
