The strap is two inch webbing with a D ring sown on one end and a loop sown in the other. There are two triangular cutouts in the female main waist buckle of the bag. It is pretty easy to thread a heavy duty split ring through the top cutout for attaching the strap to the bag. The strap is looped through the top handle of the bag, the end with the sown loop threaded through the D ring, and then the split ring threaded on to the sown loop. Add a shoulder strap pad and it is very comfortable. The pad is a $15 black Timbuk2 bought at REI.
The split ring has been replaced with a tie wrap as the light weight ring I was using, started to bend out of shape.
As both straps are attached to almost the same points, the bag retains the same functionality. The second strap evens the weight across the shoulders, but doesn't provide any more stability.
Putting on the bag is pretty much the same as before, the main strap is placed over the head and across the right shoulder. The bag is then rotated a bit around the front, enough to where the second strap can be easily grabbed and the left arm looped through. The second strap is used to swing the bag to the back while it is placed on the left shoulder.
What I normally have in the bag and why I wanted a second strap.
Rotating the dividers to make getting into the AW 200 Slingshot easy.
Thank you
Russell
