Induro AX-214 Tripod, Feisol CB-50, Kirk L-bracket, Seagull 1-2.5x right angle finder, Pentax F 100mm f2.8 macro, K20D.
This is the shot.
This is the setup. It was a bit windy. The wind was coming from the same direction as the light so I couldn't use the Tamrac Messenger 4 in the photo to block it.
I can get right down on the deck if needed with this setup. I'm pretty happy with the Induro AX-214. I see no reason to go for the short column accessory with the AX or CX series with a L bracket.
Thank you
Russell
