While it's true that a Skyport can sync at speeds up to 1/1000th of a second, part of the equation is the camera being used. Here are some things to keep in mind.
- Skyport can only sync electronic shutter cameras (point and shoot) at 1/1000th of a second.
- Skyport can sync leaf shutter cameras at 1/800th of a second
- Skyport syncs with focal plaine shuttered cameras (DSLR's) can differ based on the camera, but normally close to thier rated sync speed.
Here's the deal. Some camera manufacturers highest advertised sync speed is only available when using their own proprietary equipment or when shooting with a sync cable. When shooting with a sync cable their is no delay in sending or receiving the signal. When using a radio slave system, the signal should be encrypted, send then decrypted at the receiver, so there will always be a slight delay using these systems. The other factor in the equation is how fast the shutter opens / closes and the mirror gets up/down. Some exposure scenes may provide the top sync speed of a camera while others you will get clipping. Normally though, if you are getting clipping you can drop you speed down by one F stop and you should be in good shape.
Hope this helps.
Mark Astmann
Product Sales Manger Lighting Equipment
Bogen Imaging
