Originally posted by TYOsborn Thanks! I did surprise myself.
It was alot of fun, but a lot of work at the same time. (I still need to learn how to use that flash better as well as the settings on the camera) I'm going to post a few more in pics in the photo part so not to clutter up this forum with pics. There is one particular pic that I wanted to turn out much better than it did... Maybe you can tell me what to do right next time
I wanted a silhouette pic of her so I had her get sit in front of the window with some sheer shades. This is what I came up with some PP work.
I wish I had more time than I was allowed because I was getting into posing her. hehe
To get a sillhouette shot you should have had the camera expose with a faster shutter speed; meter the window, lock exposure, compose her and fire.
Look at the shot in your LCD and adjust as necessary. They are pretty easy to do.
A slower shutter speed would bring detail into her face which s not as bright as the window.
Practice with a still subject;
place it next to a bright light source and meter that source then lock exposure.
Recompose your subject as you want it to look silhouetted, then fire the shutter.
Adjust as necessary ie; a slower or faster shutter speed.
You will get the hang of it and may not have to lock esposure.
You can set the camera to lock AE with AF.
Then you would just press halfway at your light source point at your subject and fire.
Focus is not critical cause you are trying to get a silhouette.
This is great for the fast action at weddings.
A good shot is to have the couple kiss in front of a setting sun.
You meter the sun, compose and shoot.
You could also bracket these shots if your time with the couple is limited.
