Okay, I've been reading Strobist stuff and decided to dabble in photography with off-camera lighting a bit. I picked up a light stand, reflective umbrella and an AF 360 flash. I still feel quite in the dark (no pun intended) with what I'm doing. I was using my wife as a model last night to test out the setup, using the built-in flash as the controller, and in every shot her eyes are closed or drooping from blinking. Is there are timing issue between the off-camera flash and shutter? Would the fact that it was evening and we had minimal ambient lighting affect this? I wondered if the control flash was making her blink, so I blocked the control flash, but this altered the lighting in the photo. Any help?
Ultimately, I want a two flash setup for horse portraits, a la Yann Arthus Bertrand, but I have a lot to learn.
edit: I'm using P-TTL, is there a better way? Would the problem be solved with the Cactus V4s?
Todd
Reason: added info
