Originally posted by nicholaspaul Good point. I never thought of it that way.
And Mr Rockies, that's a great testimony. I'll definitely use the 50mm. When you say flash on top, do you mean that you don't use a flash bracket? Is that another piece of gear I can do without
Albert referred to using his 50mm on a KX = full frame. The equivalent field of view would be provided by the FA 35/2 on your camera. Your M50 will come in handy for portraits or candids, but is too narrow for group shots or for taking in the location.
A flash-bracket is a sensible choice if you use one of those small hot shoe flash guns (aka the FGZ360), because you can always position the flash on top, over the camera lens. Otherwise, when the flash is placed in the hot shoe directly, you will get very unnatural shadows, when you shoot in portait orientation.
Generally I would second Wheatfield: go for a secondhand capable flash gun with a good Auto(Thyristor) control, like the Metz 60 or 45 series. There are only two values you need to observe:
- use the same ISO setting in camera and on the flash
- dial in the aperture number you use on the lens into the dial of the flash
Metz flashes nearly always expose very, very reliably in Auto-mode. Also, these two modells have enough power for bouncing or using a portable softbox or whatever you want.
Ben
