Originally posted by SOldBear No, the flash is not modular. I think the only Sunpak model is modular is 622.
I opened up the head and looked around - everything is clean and solid. I think the cause of failure is electronic (component failure), not mechanical (corrosion, solder joints coming loose, wires broken,...).
Hrm, well, it's good troubleshooting to start there with intermittent problems, at least.
I asked about the modularity cause some of the older Sunpaks and a few Vivitars had some trouble with the connectors wearing out, once upon a time, usually with the shoe mount models and the interchangeable heads, when they had sort of an Atari-cartridge like card connection, and you could get problems like that. There's sometimes little things you can do with that.
I suppose the next question is if you feel capable of repairing little circuit boards, or maybe trying to swap out components. (This is generally outside my depth)
Do you know what's wrong with the parts-522?
