Originally posted by Pentaro Thanks for the info. Yes, the bottomless holster seems similar to HoldSLR in concept, but to me, HoldSLR seems more lean.
I'm not looking for a way to store or transport the camera; rather, I'm looking for the smartest way to draw/shoot/holster quickly. The idea is to carry two cameras (e.g. one with wide-angle zoom and the other with telephoto zoom) and quickly change camera depending on the situation. I could achieve this by hanging two cameras on both shoulders diagonally or on neck using two different lengths of straps, but the cameras will be swinging a lot in both styles.
I wonder how news reporters do it? Most of them that I've seen just use shoulder/neck straps and sometimes a harness, but shouldn't something like HoldSLR be a better solution for them? If not, why? (HoldSLR has 102mm opening and tested for 9kg cameras, according to their website.)
Could work in your particular application, I guess, though I'd still be worried about it getting lifted or in the way in a crowd. Generally how I'd run two bodies would be simply to rotate between bag, shoulder-slung strap (same shoulder) and hand. If there's a big body like medium format involved, that gets worn on strap around the neck once it's out. Kind of a triangular sort of flow: Everything's controlled that way. You could work a holster like that into a similar scheme if you weren't carrying a bag anyway and both cameras fit, though, I suppose.
(Oh, I should probably mention that I'm more skeptical than most about a lot of clever belt-carrying type systems: being smaller, I tend to find them more ungainly than others might. if I were to wear a camera on my right side I'd feel about twice as wide: when it comes to covering things in crowds I need to be able to thread my way through if I can't get people's attention.
If everything I'm wearing is on the left, that can sort of trail behind and I can move it around as I need to, while keeping my hands on everything: very habitual motions.
*further musing* I do like the unfoldeyness idea, though. I could see it for like concerts or something: once you're actually in position, you could have a little marsupial action going on right in front. I'd have to use the other kind, though: I just never use two lenses physically-long enough to hold the camera into the 'holdslr' thing, at least since I did scholastic sports with film.
It's a beauty of gadgetry, though, stuff evolves. Got to encourage the inventors. If I find I just can't keep up with shooting for a sideline, I figure I can stay in the field by making stuff, myself.
