I bought the focusing rail a while back and I did do some modifications.
The first was to fill the holes on the plastic guide behind the metal plates. I taking apart the unit, I noticed I had already bent the metal of the center plate in trying to keep the camera and lens from extending the rail when fully vertical.
I used hot glue and a hot glue gun to fill the holes. I mounted the plate before the glue cooled and hardened. It was a little messy, but I removed the majority of the excess.
I didn't always want to use the unit as a four way head as it is a little bit to carry, and I didn't want to remove the QR plate on the camera, so I added a QR mount to the lower arm.
The QR mount could not keep from twisting, so I added two set screws to the base. The set screws are positioned to allow for a 90 degree rotation of the QR mount.
I wanted a way to mount a QR plate to the base of the rail. In this case, a home made acra style QR plate made from 1.5x1/8 inch aluminum flat stock filed to shape and epoxied together. I figured drilling and tapping another hole in the base to keep the plate from twisting was needed. The mount already had the metal, just not the second hole.
A photo of the lower base taken apart.
The focusing rail cost $50 on ebay with shipping and the Kirk 1.75 inch QR mount was another $50. With another $10 for the misc screw and the four inches of flat stock, I figure around $110 for the complete set of mods. This is still a lot less than the
Kirk focusing rail at $270.
The QR mount is simple to remove and the lateral arm can be mounted in its place. The QR mount can then be mounted to the lateral arm's stand for use there.
Thank you
Russell
