Top pocket organizer with 2 internal zippered mesh pockets
• Padded 850 c.i. camera bay with weather-resistant zippers
• Hydration sleeve holds 70 oz bladder
• Modular organization including Velcro-ready Cradle Dividers
• Media organizer with weather-proof zippers to protect data cards, hard-drives, cables, pens, and business cards
• Padded shoulder straps cushion against heavy photo gear, with additional support from load-lifter straps and adjustable sternum strap
• Built-in ChestPorts™ host Clik Elite ChestPacks for fast camera access on the go
• LadderFit™ harness system adjusts to 4 different torso lengths for comfort and optimized weight transfer
• Comfort-molded back panel sheds snow and dirt, vents heat and moisture
• Padded contour waist belt with bi-directional buckle comfortably transfers weight to hips
• Stash pocket with compression buckle and small zippered pocket
• Attachment points on shoulder straps and waist belt host small pouches and lens holsters
• Mesh side pockets keep water bottles and other items handy
• Internal aluminum frame-stays add support for heavy loads
• Strap points on top pocket and bottom panel hold tent, sleeping bag, tripod, and other items
• Hide-away rain fly
• Ruggedized construction: fully lined and taped, beefy zippers, 1680D ballistic, and 420D high-tenacity nylon fabrics
• 27″h X 14″w X 11″d
• 4000 c.i total capacity
• Hydration sleeve and tube port for up to 70 oz bladder
• Padded 500 c.i. camera bay with weather-resistant zippers
• Media organizer with weather-proof zippers protects data cards, hard-drives, cables, pens, and business cards
• Built-in ChestPorts™ host Clik Elite ChestPacks™ for fast camera access on the go
• Waistbelt can be tucked away for a more streamline set-up.
• External access zippered compartment for sunglasses and other accessories
• Removable accessory straps hold additional items, such as a tripod or extra clothing
• 23″h X 13″w 8″d
• 2100 c.i. total capacity
Thank you
Russell
