06-14-2009, 11:58 PM   #1
Problem with AF-500 and manual mode
Hey guys,
Picked up an AF-500 for my K100D, and I can't get it to stay in manual mode. It keeps thinking it is in TTL, which overexposes unless you bounce off the ceiling. I push the "mode" button to go from TTL to Manual mode, and set the power to 1/16th or whatever, but the moment I push the shutter button halfway, it goes back to TTL. And, as far as I can tell, does a full-power flash every time I press the shutter. This occurs whether I'm in P, Av, or M mode on the camera.
I read somewhere that even thought its a pentax flash, that it can only be used in manual with pentax digital cameras. Is this true? I initially bought this to play around with as a second flash to my (reliable) Sunpak 333, but I don't know what the hell I'm gonna do with this flash.
Any suggestions?
06-16-2009, 10:25 PM   #2
Anyone able to help me out?
06-16-2009, 10:43 PM   #3
res3567's Avatar
QuoteOriginally posted by medbooks321 Quote
Read this. It looks like the earlier DSLR's support this flash and not the current one's. This could be because of P-TTL.
Flickr: Discussing Pentax Flash: AF 500 FTZ-Does anybody use it? in PENTAX *istDs
06-18-2009, 11:09 AM   #4
About as good of an answer as I'll get. Much appreciated.
06-18-2009, 11:37 AM   #5
im using this speed light n it worked fine with my k10d.. ( only in manual mode )
anybody knows what is the voltage output from this flash ??
this is my pic using the flash
06-18-2009, 12:19 PM   #6
Lowell Goudge's Avatar
Note that the AF-500FTZ can only work in TTL mode or full manual flash exposure mode.
I have not tried to run mine in manual as I use it principlally on my *istD which supports TTL, newer bodies only support P_TTL.
I am surprised however that it won;r stay in manual
06-19-2009, 05:33 AM   #7
just as an update, now that I am back together with my camera gear.
Put the AF500FTZ om my K10D.
set the flash to manual mode, camera in manual mode (but with an A lens in the A position)
ALl my shots were dark irrespective of flash power or selected aperture. I think some how the body was sending a preflash signal.
turned it all off, and then back on and I had no problem with manual control of the flash, and exposure with the lens in either A where the body controlled aperture or by setting aperturee manually.
all seems to work for me, flash always stayed in manual
06-21-2009, 03:44 PM   #8
Thanks, Lowell. I finally got mine to stay in manual mode as well. The problem (i think) was that i had the flash in rear curtain sync, which, for some reason, was not compatible.
af-500, button, flash, mode, pentax, shutter, tripod, ttl
K-x Problem with manual mode and M42 lenses dude163 Pentax DSLR Discussion 10 08-11-2010 04:16 AM
Any Pentax 500/4 manual focus equivalent kenyee Pentax SLR Lens Discussion 13 03-09-2009 08:28 AM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
ISO in manual mode dustartist Pentax DSLR Discussion 16 03-21-2008 06:27 PM
Sigma EF-500 Super Problem. blwnhr Pentax Camera and Field Accessories 0 07-02-2007 03:48 AM
All times are GMT -7. The time now is 01:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
