06-16-2009, 11:17 AM   #1
bwield's Avatar
Eye Cup
Could not find any results in the Search
Does anyone have any experience with the aftermarket Eye Cups.. like this one:
Eyecup Eye Cup for Pentax *IST SP MZ *istd *istds on eBay.ca (item 330307708472 end time 13-Jul-09 13:07:06 EDT)
Are these any better than the original eye piece on the K20D.
Mine has ripped and when looking for a new one I found these.
Any advise would be appreciated
06-16-2009, 12:07 PM   #2
blackcloudbrew's Avatar
I've already ripped one on my K10d. Did a little research and while I might have been able to get them cheaper like on EBAY, I ordered two more direct from Pentax. However, you could consider something from HoodMan:
HoodEYE-Hoodman Corporation
Tim
06-16-2009, 02:07 PM   #3
pbo
pbo's Avatar
Hey, Tim, I also ripped one on my K10D - when I just got the camera, thought it was the way it was supposed to come off, you know
Anyways, there's one almost similar on ebay - search "pentax FO". The tricky part is that eyecups consist of two parts - two plastic and a rubber part (and screws), and rubber parts are identical, while the plastic part from ebay eyecup is a bit loose when on camera. The thing I did was replace the torn rubber part from my original cup with ebay's rubber part - and voila! it looks the same, feels the same, and sits solid on camera, just like my original FP eyecup (FO is supposedly for K2000, but the way I did, it works well on K10D, too).
06-16-2009, 02:09 PM   #4
pbo
pbo's Avatar
bwield, I have one of those - I won't recommend them, they fall too easily from camera; the one I had also had loose screws - but that's easily correctable.
06-22-2009, 01:20 PM   #5
bwield: Are these any better than the original eye piece on the K20D.
I have not used those, but love the aftermarket one I got with my KPS 1.35x magnifer. It seals my shooting eye from light outside the viewfinder, causing my pupil to dilate, making manual focus much easier.
cup, eye, tripod
Rubber Eye-cup Identification gofour3 Film SLRs and Compact Film Cameras 7 09-10-2010 04:52 AM
K10D Eye-Cup Buddha Jones Pentax Camera and Field Accessories 3 10-29-2008 09:19 AM
All times are GMT -7. The time now is 01:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
