06-30-2009, 03:15 PM   #1
SIGMA EF 500 DG - good for pentax k10d?
a flash SIGMA EF 500 DG is good for pentax k10d?
I read that EF-500 needs a firmware update for the K10D, K20D, K200D, K2000.
06-30-2009, 03:47 PM   #2
QuoteOriginally posted by gemini Quote
I have the 500ST model and before I upgraded to K20D I made sure that it does not need a chip update. It just works.
It is just slightly inconvenient as Sigma centre is just 20 minutes drive.
Daniel
06-30-2009, 03:53 PM   #3
QuoteOriginally posted by danielchtong Quote
Daniel
thanks for info
so there are some ef500 good for k10d\k20d and some ef500 not good for k10d\k20d.
and if a ef500 is good on a k200d, it will be good also for k10d\k20d ?
06-30-2009, 05:00 PM   #4
The EF 500 DG Super will work fine on Pentax cameras. The update was needed to correct an "out of sync" problem when using the flash in wireless mode piloted with the on board flash. The upgrade was done free of charge by the Sigma's distributor. To verify if the upgrade was done, try the flash in wireless mode with the on board flash set as controller, and see if the shadows are falling in line with the Sigma flash.
06-30-2009, 05:46 PM   #5
I think K200D came out the same time as K20D so very very high chance. K00D for sure. If rechipping is not workable for you even though Sigma will do that for free, then make sure you test it out.
Daniel
06-30-2009, 08:42 PM   #6
Peacekeeper's Avatar
I have the EF500 DG ST not the Super. It had to be re-chipped to work with the K10 and subsequntly works on the K20 as well.
If it works on the K20 it will work on the K10.
The Later versionsof the EF500 that were produced at the same time or after the K10 was produced WILL work wothout re-chipping.
Best way to find out is to test it before you buy.
PK
dg, ef, ef 500 dg, k10d, pentax, sigma, sigma ef, tripod
Used Sigma Bigma 50-500 for $635usd..Good Deal 68wSteve Pentax SLR Lens Discussion 3 07-15-2009 06:01 AM
A good tripod for the Sigma 150-500? Xcom Troubleshooting and Beginner Help 2 04-20-2009 02:25 PM
K10D and Sigma 50-500 test Heinrich Lohmann Post Your Photos! 12 12-08-2007 03:46 PM
Sigma EF-500 DG ST Flash Firmware Update For Pentax K10D stewart_photo Flashes, Lighting, and Studio 3 08-10-2007 07:06 PM
Sigma DG 500 Super on K10D peted Pentax Camera and Field Accessories 4 11-29-2006 05:33 AM
All times are GMT -7. The time now is 11:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
