07-16-2009, 04:14 PM   #1
How much does your tripod leg vibrate?
I read with interest Stevebrot's review of the Giottos MT9370. He mentioned:
[B]While it is pretty stable at full extension, there is still a tendency to vibrate. Collapsing the final leg sections allows for a significant increase in stability with little tendency to vibrate.
I was at Adorama last week and I put a number of Carbon fiber display units to a vibration test. I fully extended the legs and gave it a simple finger tap (like knocking on a wooden door).
I found that all but the Flashpoint 1428 vibrates visibly, and none stop vibrating faster than the 1428. My guess is that the 1428 have a largest tube diameter 37mm, while all the other are either 28mm or 31mm.
Does your carbon fiber vibrate like this? Is it an issue?
07-16-2009, 07:14 PM   #2
heatherslightbox's Avatar
I'm curious--which other tripod legs did you test? Were there any Gitzos among them?
Thanks!
Heather
07-16-2009, 07:29 PM   #3
jem
Just checked my Bogen 3021 (older manfrotto 055), Giottos MT 9371 and Gitzo GT5541LS. They all vibrate to some degree though the Gitzo is so minimal I had not noticed untill I was looking for it. By the way, a rubber bungee wrapped around the legs will pretty much eliminate that type of vibration.
07-16-2009, 07:30 PM   #4
QuoteOriginally posted by hwblanks Quote
Definitely Manfrottos, Giottos, Flashpoints, and Induro. Don't remember giving the Gitzo the finger tap test.
07-16-2009, 07:47 PM   #5
QuoteOriginally posted by jem Quote
Do you think the Gitzo vibrates less because of larger leg diameter?
Does your Bogen/Giottos tends to produce less in focus pictures than the Gitzo due to vibration?
07-16-2009, 08:14 PM   #6
jem
QuoteOriginally posted by song_hm Quote
The larger diameter is one factor. Both the Bogen & Giottos being constructed of aluminum is another factor. I placed them on a tile floor for my test because carpet dampened the vibration to a great degree. I could barely detect any vibration on the carpet. By the way I have a QuickSet at work with nearly 3" diameter legs that I can still see vibration even in lab conditions. Note that one of the lenses I use has approximately a 1/10th of a degree FOV (with our focal plane) so I can see lens motion caused by traffic vibration. It can be quite challenging to do measurements.
Sure - if I don't compensate for their limitations. There are a number of things I do to dampen vibration depending upon the conditions in which I'm shooting. Weight, bungee cords, extra bracing, careful selection of location, wind shielding and floor surface, my own body, etc. - lots of things. And obviously the better tripod helps a lot. The Gitzo is primarily for my long lenses whereas the Bogen & Giottos are generally good for most everything else though I am still tweaking my macro setup.
07-16-2009, 08:32 PM   #7
Marc Langille's Avatar
Which brings up an entirely different but very important point Jem!
General comment: long lenses, even with excellent support systems, are subject to this vibration as you rightly indicated. That's where the difference in sharper images are dependent on your long lens technique, even with top shelf support gear. I've come away with keepers at such low shutter speeds that I was frankly surprised at the clarity/sharpness.
Real world situation: even inadequate support systems are OK in a pinch, but it's much harder to regularly get crisp shots and move the lens smoothly. Dampening the setup with both hands and your face can overcome a lot of those issues, although I would not want to stick with that scenario for very long!!
07-16-2009, 09:04 PM   #8
There are a number of things I do to dampen vibration ... bungee cords ...
How do you use the bungee cord? Can you post a picture?
How long a lens would begin to require the Gitzo? SMC-M 200/f4? Or Vivitar S1 70-200? DA 50-135?
QuoteOriginally posted by Marc Langille Quote
Ok, spill the beans Marc. What are your good long lens technique?
Especially in the middle of winter :-)
07-16-2009, 09:21 PM   #9
jem
I wrap it horizontally around the middle or upper joints of all three legs of the tripod in question. I'll try and post a photo tomorrow.
That tripod was bought specifically for my F*600 f4 pictured here. It is capable of holding the considerable weight comfortably with some (believable) margin. A tripod like this is probably overkill for a much lighter setup. By the way, as a rule I like a factor of 2 or more in weight handling versus actual weight load. Also, I generally don't believe the manufacturers' specs. I think they are generally "optimistic".
07-17-2009, 03:25 AM   #10
John, that's a good idea = picture please. Of course that setup would make sense, assuming the cord is stout and tensioned well.
Long lens technique... hmmm... I am going to do it at the workshop... Are you coming?
Banter aside: at some point I'll do an article or writeup on the various ways to dampen vibrations for long lens shooting. I had plenty of practice with a much lighter 500mm on very windy days - not fun. It's a 7lb lens vs. ~15 pounds for the Pentax 600/4 lenses. Thus your control and technique over the setup is often critical, especially in adverse conditions - it will make the difference in obtaining the sharpest image possible.
Of course, John's 600/4 + Gitzo+ MKII setup would require hurricane force winds to get a little resonance happening... just saying...
Agreed...
07-17-2009, 05:00 AM   #11
jem
Will do!
Well I do live on the Gulf Coast...
07-17-2009, 03:25 PM   #12
jem
Here you go guys! Note that the bungee can't be too tight or it will pull the legs together. I use one (or more) of those Velcro computer straps to adjust the tension on the bungee so that it is not too tight. The main idea here is to dampen vibration or other resonances in the legs from wind, traffic, large herds of big footed tourists, etc. A plus is that it will fix the dead weight (gear bag) in place and the bag will dampen bungee cord vibrations. Yes, they can vibrate too. I’ll use this setup with spiked feet if the surface I’m on is suitable - small sand bags if not.
By the way Marc, the last photo in particular is for you. Thanks again for driving my LBA!
07-17-2009, 04:14 PM   #13
Otis Memorial Pentaxian
Are we going to have to start a Giottos Club
I posted a shot earlier today that prominently featured mine!
(At least I think that looks like a Giottos...)
07-17-2009, 04:40 PM   #14
jem
What? No Link? You made me look for yours... Hey - we gearheads have to stick together!
Yep, MT 9371 here... Officially demonstrating a long lens technique... Covertly showing off my new macro lens...
07-17-2009, 04:47 PM   #15
If you insist:
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/45892-sightsee...tml#post672383
carbon, fiber, leg, tendency, tripod, tripod leg
DIY: Tripod Mounts using Leg protector and Shoulder Strap raider Do-It-Yourself 20 01-09-2012 08:53 PM
Who ate my leg? bubblesT Monthly Photo Contests 0 09-01-2010 08:43 PM
Tripod Leg Sticks, Help Please Rodney9 Pentax Camera and Field Accessories 5 11-06-2009 05:43 PM
DIY tripod mods - Leg protector and Shoulder Strap raider Pentax Camera and Field Accessories 22 04-13-2009 11:31 PM
Fly on my leg! KevinJ Post Your Photos! 10 08-26-2008 01:39 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
