I bought a couple of the new
PT-04TM II receivers as they now have a sync port on the side. These also come an improved mount.
The new mount is on the left, old on the right. That little edge of metal is all it takes to have a very secure vertical or 45 degree tilt with the flash mounted. As I'm not going to use the mount on the new pair, I moved them to the older PT-04TMs. They work there just as well.
Thank you
Russell
