I have a K20D and two 360FGZs and access to a third. I want to fire all three flashes wirelessly.
What I have tried;
1) Set the camera's on board flash to master, set the two 360s to slave, set channel 1 on both flashes. Sync the Camera to Channel 1 and set the on board to wireless mode. Set both flashes to first curtain sync. Turned them on to wireless and attempted a frame. Result: only the flash that was 'synced' with the camera and the onboard fired.
2) Same as above, Only I set the on board flash to controller. Result; only the 'synced' flash fired.
3)mounted one of the 360s on the camera hotshoe, set that flash to master. Result; both flashes fired .... I don't acutally have the third 360 to see if the mounted 360 can master two other flashes.
So... can I fire two or more 360 FGZs using the camera flash as the master/controller, or will I need to have the 540 to do this... or it is not possible to have more than one wireless flash.
If the above can be done... any ideas as to what I'm doing wrong?
Thanks for any advice.
