07-28-2009, 02:57 AM   #1
johnnyboy114's Avatar
Trigger voltage for K100D
Hi guys
I am new to this site and could do with a few pointers for a newbie regarding flashguns...
What would be the maximum allowed trigger voltage for a K100D? Does anyone know? I have done a search on here and the answer seems to be quite vague. Its not in the manual for the camera and others don't seem to have a spot on figure. The consensus of opinion seems to be "around" 30V. Is this the case?
I am looking to get an older flash gun to try a bit of off camera flash work (I intend to buy a cheap remote trigger), so that shouldn't be a problem. But if I decide to use the flash ON the camera, it would be nice to know if I am going to blow the camera up or not! lol! I have been using my K100D to pretty good effect of over the past couple of years but have resisted the flash route, but now I want to try something different. I hope you can all help!
Thanks in advance
Cheers guys
John
07-28-2009, 03:23 AM   #2
Welcome to the forum, John.
I posted the same question about a year ago and was told the trigger voltage is "about" 25V for Pentax DSLRs. I had an old Incablitz flash given to me and wanted to try it, but after reading a bit more I decided to sit on it. All the camera shop technicians I've asked have said it's OK to use the flash, but it could be a very expensive mistake if they're wrong. I'll follow your thread with great interest. Any idea how you test the voltage of a flash unit?
07-28-2009, 03:30 AM   #3
Hi Wombat
No, not got a clue how to test the voltage of the unit, although on other forums and sites I have seen people test them with voltmeters and similar gadgets. I am not an electrician, so wouldn't know where to start with this! But it seems like its quite a popular way of going about things.
As for the voltage the camera can take, your ballpark figure is pretty similar to the one I have seen bandied about in various places. I have options on a couple of older flashes, so need to know both the camera capability and the flash voltage and can't seem to get any info on either! I am hopefully primarily going to be using it off camera anyway, but I just want to know if I have the option of blowing the camera to bits!
Keep looking, cos I will be! Hope the thread comes up with something and answers your question!
Cheers
07-28-2009, 05:01 AM   #4
Class A's Avatar
QuoteOriginally posted by johnnyboy114 Quote
Appears to be <= 30V for Pentax DSLRs.
Note that the camera may survive higher voltages a couple of times but not indefinitely often.
A trigger voltage of <= 5V is definitely super safe as all Pentax flashes are within in this range.
There are several ways to completely avoid any risk or use high trigger voltage flash monsters: Use a Wein hot shoe adapter or use a radio trigger such as the Cactus V4. The latter has the added advantage that you will move the flash away from the camera, either with a flash bracket, your other hand, stand, or assistant.
To measure the trigger voltage of a flash make sure you use fresh batteries and a digital voltage meter (analogue ones may give you a false reading). Let the flash completely charge and then simply measure the voltage between the hot shoe contacts.
Since you are a K100D user, you may be interested in this "tips and tricks" article.
07-28-2009, 05:21 AM   #5
Thats fantastic information Class A! Nice one and MUCH appreciated! Will check on that and seems simple enough to measure. The radio trigger was going to be the way I was going to go mainly anyway and you have given me a couple of names I hadn't heard about. I shall check them out and check out the tricks and tips!
Thanks again and MUCH appreciated!
07-28-2009, 12:52 PM   #6
alohadave's Avatar
If you have a flash that you are looking at buying, you can check the voltage here: Photo Strobe Trigger Voltages
07-28-2009, 01:34 PM   #7
Thanks Dave! Very useful!
camera, flash, guys, k100d, tripod, voltage
Safe trigger voltage for K-x Pentax Bob Pentax Camera and Field Accessories 9 09-08-2010 06:45 PM
What exactly is trigger voltage? Workingdog Pentax DSLR Discussion 11 01-09-2010 02:20 PM
trigger voltage axl Pentax Camera and Field Accessories 6 03-12-2009 03:52 PM
trigger voltage K100d Super gshin Troubleshooting and Beginner Help 13 02-28-2009 11:36 AM
K100D trigger voltage toleration? uPiX Pentax Camera and Field Accessories 3 08-05-2007 04:18 PM
All times are GMT -7. The time now is 12:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
