08-06-2009, 06:22 AM   #1
P-TTL problem with istd??
i shoot nightlife photos, so i need something for very lowlight.
after not doing my reseach, i purchased a regular sunpak flash and realized it didn't help at all.
i read about the p-ttl system, so i invested in the Digital Concept 918AF. i needed a (cheap) flash to autofocus with an assist before i could shoot the picture-otherwise i can't see what i'm doing!
i read a great review of it on here-problem is, mine's not working! since i'm new to working with p-ttl, i'm wondering if i'm doing something wrong. i've tried p, tv, av, manual setting-no assist. the flash is fine in bright light, but does absolutely nothing in the dark.
is this a setting? or is possible the flash is defective?? or did ebay lie to me, and it's not even compatible with an istd???
08-06-2009, 11:12 AM   #2
I don't know much about the flash unit you mention.
But I know that ist-D does not have P-TTL. It's TTL. You may want to make sure the flash supports TTL.
Your description of the problem ("the flash is fine in bright light, but does absolutely nothing in the dark") does not sound related to P-TTL vs TTL, however.
08-06-2009, 12:32 PM   #3
QuoteOriginally posted by SOldBear Quote
*ist d does support p-ttl flashes from what i understand. p-ttl causes a flash before taking the picture so that the camera can see enough to focus. mine, however, is not doing this preflash-that's my problem
08-06-2009, 12:37 PM   #4
QuoteOriginally posted by yinzerparty Quote
Sorry. My bad. As you said, *ist-D does support P-TTL.
The pre-flash strobe is for metering, not for focusing. The focus aid is the near-infrared pattern light output from a separate bulb.
08-06-2009, 01:16 PM   #5
Lowell Goudge's Avatar
actually, and the *istD and DS are the only two like this, they support both TTL and P-TTL
the way it works is as follows
if you have an A series lens, and a TTL only flash the *istD will automatically sense this and run in TTL mode (at least mine does this with the AF500FTZ)
If you have an A series lens and a P-TTL flash, it will run atomatically in P-TTL mode.
If you have a flash that supports both TTL and P-TTL like the AF 540 FGZ and a non A lens, then the camera and flash automatically switch to TTL.,
The flash capabilities of the *istD are one reason I have always kept it as a spare body
08-07-2009, 01:27 PM   #6
so this is where i think i get confused. the pre-flash is to determine how strong the flash should be for proper exposure?
i was hoping p-ttl would help me out with the low light i encounter going to concerts and venues. do you think it will help in that case?
either way-the flash doesn't work in anything but a bright room. i'm assuming it's defective, so i'll return it and see if another ones works.
08-08-2009, 06:13 AM   #7
Wheatfield's Avatar
I found the istD flash control to be worse than useless, either TTL or pTTL. Just get yourself a good autoflash, Pentax flash control pretty much bites.
assist, flash, p-ttl, tripod
istD battery compartment problem Vranx Pentax DSLR Discussion 11 08-01-2013 12:25 PM
Problem with Flash card in *istD davidjones Pentax DSLR Discussion 4 08-06-2010 08:43 AM
Metz CL-1 & *istD Problem falconfixer Troubleshooting and Beginner Help 6 06-01-2009 01:16 PM
P-TTL problem Hey Elwood Pentax Camera and Field Accessories 14 03-14-2009 05:42 AM
RAW Problem with my istD thomas81 Pentax DSLR Discussion 3 02-19-2009 10:28 AM
All times are GMT -7. The time now is 05:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
