Great project. Thanks for the ideas.
I used a $2 plastic bowl, a old DVD case, a $2 mirror and a $1 can of high gloss white spray paint.
I cut a hole in the bottom of the bowl big enough to fit the dvd case. I used the bottom piece I cut out to super glue to the top of the dvd case. Attached the mirror to that. Cut a hole in the base of the dvd case to insert my AF360fgz. Then I painted everything white.
Assembled dvd case.
Back of the bowl with the dvd case inserted
Front
Testing
Example
Took no time to make and I only spent $5.
Never used a dish before, how did I do?
