Originally posted by séamuis this is what I was thinking as well. if the inside of your house is humid enough to warrant such a box, wouldn't using it to store equipment just lock moisture inside the box? that would be the perfect breeding ground for bacteria and fungus would it not?
I put all my stuff in plain sight with plenty of circulation around em...aka on top of my speakers, media center, bookshelf, etc...so far so good, except for the dust flying around.
Originally posted by StevenVH True, but the interior space is small compared to a room and is easily dried out by the desiccant.
Sticking a bag inside is a good idea. It's not submersible, but definitely splash proof and you can sit on it too
Yeah, the watertight box would be nice just in case the boat decides to stop floating
Originally posted by StevenVH True and cheap. The desiccant packs I have are from an Ebay coin dealer, @2"x5" perforated metal with a little indicator window. When the window turns pink put them in the oven for a couple of hours to dry them out.
cheers
I have one of those, and it goes "pink" really fast...I mean like under a week. Granted, the box wasn't air/water tight but the concept is the same...every time it's opened, the desiccant is exposed to moisture.
Personally...I thought about getting something like this for things I don't use often or won't be using if on a trip, etc. Maybe have 2 boxes...one with stuff you use a lot, with 2 "tins" and then one used for storage with just one. Something like that
