Originally posted by PrasKulk Hello All,
I am having problems with the photographs being underexposed when I use the K20D with the AF-360FGZ flash. The photographs are a lot better with the built-in flash on the camera.
I use the external flash exactly according to the instructions in the flash manual (P-TTL, Auto Zoom etc).
Could someone please help with why my photos are underexposed when using the external flash but seem to be OK when using the built in flash.
Please help.
Thanks,
PK
Mine acts exactly the same way. Built in flash is fine, but the 360 exposure in P-TTL is erratic, with most being under exposed. I wouldn't mind using "auto" if some genius designer or programmer hadn't decided that "auto zoom" should not be available in "auto". (but auto zoom does work in "manual". Go figure!)
