A few weeks ago I picked up a Soligor ringlight from a local Craigslist - nothing fancy: 2 auto settings and full power manual.
It works great after I get to know how to use it. The only annoying thing is that it's a hassle to attach and detach the ringlight to/from the lens. The flash uses Series VII adapter. I have multiple macro lenses with different filter thread diameters. Keeping track of adapters of different sizes is no fun.
The other day when using my Raynox 250, I thought of using the Raynox Universal Adapter for the flash.
So I use 2-part epoxy to attach a 62mm-to-Series VII ring to the Raynox Universal Adapter:
A ring with diameter less than 62mm will not have sufficient gluing surface; and there will not be enough room for the Raynox lens. Here's the complete Raynox 250 with the 62mm series VII ring glued to the Universal Adapter (underneath is another 62mm series VII ring):
Now I can quickly attach/detach the ringflash to/from any lens with filter thread diameter from 52mm to 67mm. Here's a setup with the Tamron 90mm:
Some quick test photos:
I can quickly detach the ringlight and hold it to a side as an external flash if I don't want the ringflash effect:
As ringflash:
As external flash:
If you don't have the Raynox Universal Adapter already, it is available for about $6 + shipping as from
here. Make sure you buy the adapter for CM2000 macro lens, not the one for CM3500 macro lens.
