You'll need a micro cloth anyway, so why not make it a
18% gray micro cloth?
I tested it against an
neutral Expodisc, and it is exactly 200 K warmer, i.e. the same as an
Expodisc Portrait. Folds up rather small, light, if you drop it it won't roll, dent, or break, and when folded in quarters, you can hold it in the palm of your hand for use in setting manual WB. If you have a lot of bags, having one in each bag isn't going to be expensive as they are only a few dollars each if you buy
multiples. I've actually seen them in camera stores now, so you don't have to buy just from Ebay anymore.
The
Expodisc was my first WB tool purchased. It has three uses, setting manual WB, sensor cleaning, and turning the camera meter into an incident light meter. Manual WB is pretty easy, just clip the Expodisc on the lens, and run though setting a manual WB. For sensor cleaning, I thought I wouldn't need it with the K20D' built in dust map, but it still comes in handy when I don't have a white wall to use. Just clip it on the lens and point the camera at a light source and either use the dust map feature, or on the older cameras, capture a jpeg. For the incident light meter same deal, clip it on the lens, point the camera at the light source and either lock the AE, or if in M mode, hit the green button to set the exposure.
I didn't actually explain all the ways to use the Expodisc as a incident light meter, but you can read the
Expodisc digital camera manual to find out more.
Thank you
Russell
