I will not submit a full write-up on this thread for reasons of brevity.
I found I definitely needed a shim with my (HK) double 45 split screen, and an extra modification to the screen's width to enable it to drop into the inlay in the viewfinder.
I did a few measurements... the existing copper shim in my camera was
0.35mm.
to summarise... I checked focus with a 28mm lens at closest distance, with the lens wide-open. It seemed the easiest way to exaggerate any error when trying out different shims.
Many plastic packages that are intended to be thrown away have good potential for use as a shim, rather than paper which may compress or absorb water vapour. I used a piece of white translucent acetate sheet.
This shim, at
0.24-0.25mm gave an excellent result. I cut the U shape out (to match the original shim pattern) with a surgical knife. Its fiddly to place the piece of plastic shim and making sure it stays there as you struggle with the screen and clip.
This modification has worked extremely well so far. I'm not suggesting all cameras need reshimming, it may be the 3rd party screens don't sit right in the finder recess properly, tolerances in either respect are stressed, or that the screens are easily misinstalled. Certainly my camera body had a pre-existing error which required this mod.
Hope this info is of help.
Reason: Added extra information and conclusion
