I've been investing in Kenko Pro1D filters for the simple reason that they are the only wide filters I know of with a front thread. The filters only stick out from the lens about 5mm so work at 10mm on the Sigma 10-20mm f4-5.6. Even better, the Pro1D filters can be used with a Cokin P wide holder on the Sigma at 10mm.
The Cokin P wide holder will only hold one 85mm square filter. It is possible to also use the Cokin CPL with the wide holder, but it is only 72mm wide across the glass. This is too small for the Sigma 10-20mm.
I currently have a Pro1D UV for use when the environment calls for it, a CPL, and a ND8 filter. Each can be used with the Cokin P holder and thus a GND filter in the holder. The CPL is pretty easy to use with the Cokin P holder. Simply rotate the whole assembly to set the CPL, then place a thumb on the CPL to keep it in place, and finally rotate the Cokin P holder around till it lines back up. It is a two handed operation, but doable.
I know some will say just hand hold the Cokin P filter, but unfortunately, I'm just not able enough to do this to my satisfaction.
Thank you
Russell
