Originally posted by bladerunneruk Hi there, been thinking about tripods recently and read the tripod review sticky 2nite, noted that some balheads can get a bit close to the legs for comfort (i.e. might scratch). Do you have any pics of your tripod+head combination both folded and unfolded please ?
Check my avatar. That's a set of Manfrotto 055B legs and the Manfrotto 0168 ball head. The ball head uses levers rather than knobs. The 0168 has the hexagonal quick release plate. That's what they had when I was in the market for a good tripod, having purchased my M 400/5.6. There is a lever to lock the ball. Tension can be adjusted by the amount I move the lever. The second lever is a pan lock. The whole head above the mounting plate will turn without any up/down movement with the ball locked and the second lever unlocked. It's great for panoramas, provided I level the legs perfectly. It's old, and does not have any levels. They would be very nice, but the rig has worked quite well for over 20 years now.
