Originally posted by StarDust I assure you that they are temperature sensitive. They always work accordingly when not cooled down (or not at all i.e. misfire) but when under a certain temperature, about 8 degrees Celsius they go down to 1/15 s.
I have been using them while snowing, both the older gen. flashes AF280T & AF200T works great and sync. Only the 540 give me 1/15 sync.
I just try put the 540 set on the heater outlet, when I just put it there it doesn't sync, but after 1 min, it sync at 1/180... so is that mean the new gen. flash need a warm up?
