Quote: make sure to get one with focus brackets in case you ever use select AF point.
There are no focus brackets on third-party split-image screens. I thought I'd buy one with rule of thirds grid to sort of asses where they are, but unfortunately focus points are not on the thirds... Try live view with grid and AF points overlay, and you'll see the actual points are a bit inside the thirds lines intersections.
Spot metering really doesn't bother me. Just never used it - either center-weighted, or matrix. Matrix actually makes sense, with all the DR k-x has.
Well, I will still buy one with grids
Just wanted to make sure k-x and k-m had the same screen (specs on VF and focus screen seem same)
