11-01-2009, 09:49 PM   #1
LeDave's Avatar
K-7 LCD screen protector
Are there any quality LCD screen protector for the K-7 that also comes in 2 pieces to protect the back LCD and top LCD other than the one from ACMAXX?
11-02-2009, 05:23 AM   #2
Dom
Guest
I use sticky back plastic, it works very well and is harder wearing then the 'proper' sticky screen protectors. The ACMAXX does look good though.
11-03-2009, 12:31 AM   #3
beem's Avatar
I had a bad experience with the ACMAXX (see attached pic). The ACMAXX is supposed to seal around the LCD screen along the border of the protector, and "float" above the LCD in the body of the protector. In my case I wasn't able to get rid of an air pocket that formed in the middle. I bought it as others seemed to have had good experiences with it so my issue may be an isolated incident.
In the end I ended up going with the regular sticky protectors. I got mine here:
3 Screen Protector Pentax K-7 on eBay.ca (item 380164185071 end time 30-Nov-09 20:25:57 EST)
Seems to generally do the job.
GR DIGITAL 2  Photo
11-03-2009, 11:52 PM   #4
Pentaxor's Avatar
if you want, you can customize a cheaper but equally effective makeshift screen protector. cut a sticky laminated plastic cover to the size of your back LCD screen and top lcd screen. this particular pressed plastic sheet sticks to your glass lcd screen, so there's no need to apply any sticking or holding solution. it would prevent your lcd from scratches or any unwanted residue on your screen.
11-04-2009, 12:02 AM   #5
LeDave's Avatar
QuoteOriginally posted by beem Quote
That sucks man! Have you tried contacting the seller about this occured defect when putting on your screen?
11-05-2009, 01:15 PM   #6
FWIW, I could never get the bubbles out of the screenpatronus protectors when I had the K10D...
11-05-2009, 05:04 PM   #7
beem's Avatar
QuoteOriginally posted by LeDave Quote
I did. I was willing to go for an exchange but they didn't seem to want to go that route so I sent it back for a refund, which I never got. I sent it back a day or two after the 7 day policy so I guess it was my fault in a way.
11-06-2009, 05:15 AM   #8
I use Hoodman for the back lcd and I don't usually worry about the top one. I have never had a problem keeping the top clear. ( I better knock on wood ) I suppose I could cut one down to size.
The hoodman seem pretty clear but I have never tried the ACMAXX. I will have to investigate.
11-06-2009, 02:10 PM   #9
LeDave's Avatar
I just bought the ACMAXX LCD screen protector set for the Pentax K-7. I will post up a picture review when it comes. Hopefully it won't end up like beem's, I'm pretty sure he was unlucky and received defective one somehow.
11-06-2009, 10:02 PM   #10
If not too indescrete, who much was the ACMAXX LCD screen protector set for the Pentax K-7?
11-07-2009, 07:40 AM   #11
LeDave's Avatar
QuoteOriginally posted by mba1971 Quote
It's expensive man, under 27 shipped. Hopefully it's worth it.
11-07-2009, 10:33 AM   #12
monochrome's Avatar
I have a remainder supply of Palm Pilot screen protectors. I tape a piece of paper to the back (and top) of the camera and trace out the shape of the LCD, leaving a small tab for removal.
Cut to size, and, Voila!
They cost $3 for ten - they were intended to be replaced frequently as they were scratched up by the stylus. I never did.
k-7, lcd, protector, screen, tripod
LCD screen protector Tony3d Pentax DSLR Discussion 9 10-26-2010 01:48 PM
Cleaning LCD for Screen Protector jeffshaddix Pentax DSLR Discussion 3 07-16-2010 04:48 PM
Acmaxx 3.0 lcd screen protector mba1971 Pentax Camera and Field Accessories 2 11-05-2009 04:23 PM
LCD screen protector for K10D heatherslightbox Pentax DSLR Discussion 21 02-16-2008 08:55 PM
LCD Screen Protector squarerigger Pentax Camera and Field Accessories 9 03-26-2007 09:14 PM
All times are GMT -7. The time now is 08:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
