11-03-2009, 03:27 AM   #1
fearview's Avatar
(old timer) How to read this old timer light meter?
lately i just grab a deal of largely collection Pentax gears from an old Pentax Shooter. One of the itme is a lightmeter from Hanimex .. series is PR120. seem after i put an LR 44 battery it can move its needle. but how actualy read this? i figured out that i need to point to the object ..set the ASA..look into the needle pointing which number .and move the plate which have 1 to 9 numbers according to it. set it to the white line on the ON-OFF switch lever. is that true..?
anybody know this thing?
11-03-2009, 05:26 AM   #2
Wheatfield's Avatar
Set your ISO by turning the inner dial, point the meter at your subject (if it has a white plastic dome, then point it at your camera from the subject) and read the number off the galvanometer. Rotate the outer dial until the number is pointing at the H or L, depending on if you have the light limiting window open or closed (high/low light being let in).
The time aperture combinations are then displayed at the bottom of the dial.
move, needle, pentax, timer, tripod
HDR and 2 second timer Ouroboros Pentax DSLR Discussion 16 11-23-2010 10:18 AM
First Timer ! Adam Lucas Welcomes and Introductions 1 08-26-2010 04:49 PM
I want to be in focus using the Self Timer OhSnap Troubleshooting and Beginner Help 13 07-29-2010 03:05 PM
K-x AF after self-timer for Self-portrait sir.b Pentax DSLR Discussion 7 12-30-2009 07:53 PM
Interval Timer pjmarchand Pentax DSLR Discussion 2 07-13-2008 05:40 PM
All times are GMT -7. The time now is 05:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
