I found these posts on the Strobist blog
here.
Codiac2600 said...
With the Pentax K10D you have to switch your flash to HS (high speed) mode and set the camera to M (manual mode) and you can punch in any combination of aperture and shutter speed (yes 1/4000) and it works like a charm. Go Pentax!
Codiac2600 said...
Withe the K10D Gene you have to set the camera in M(anual) mode and set the af360 or af540 flash to H(igh-speed). In manual mode you can punch in up to 1/4000 and it will sync just fine, but you're going to have to max out the flash power and keep it in close to see any effect. Hope this helps Gene and it should also be in the manual as well from what I remember.
Is this at all possible, has anyone tried or replicated this? Would this at all possible with the K20D?
