11-14-2009, 09:14 AM   #1
AF-540FGZ zoom stuck at 16mm??
Anyway to reset the AF-540FGZ? In P-TTL (or any mode for that matter), auto zoom is stuck at 16mm (and it is flashing). No way to change it. When this flash works, it is awesome, but I have had too many issues with it.
11-14-2009, 09:25 AM   #2
vizjerei's Avatar
so do you mean even you are using a 50mm lens it doesn't auto zoom the flash when you half press the shutter button?
11-14-2009, 09:45 AM   #3
QuoteOriginally posted by vizjerei Quote
Right, it doesn't matter what lens is on the camera. Auto Zoom is 16mm, regardless. I cannot even engage manual zoom.
11-14-2009, 09:59 AM   #4
Interesting... I read some others with similar problems - sometimes caused by the wide angle panel not being in the proper position. Now, after playing with that, its stuck on manual zoom - 13mm.
11-14-2009, 10:12 AM   #5
vizjerei's Avatar
oh no.. time to send it to fix.
11-14-2009, 01:11 PM   #6
I am having a similar problem with my AF-360-FGZ. When I turn it on, it makes a high pitched humming noise for a few seconds. Then it won't zoom (both auto when the focal length is changed on the camera and when pressing the zoom button).
I tried changing the batteries, but no luck.
11-14-2009, 01:19 PM   #7
I bought this used from B&H. I think I need a refund. Hopefully they can work with me and get this resolved.
11-14-2009, 02:02 PM   #8
The contacts in the wide-angle panel think the panel is out.
Pulling the wide-angle panel out and pushing it back in several times may fix the problem.
I think it's pretty simple to fix because the cause is just mechanical, not electronic. If you want to give it a try, this thread may help: Linky
you can see the switch in one of the photos.
11-14-2009, 05:27 PM   #9
QuoteOriginally posted by SOldBear Quote
I really appreciate the response and the link. I *may* give it a shot. I am going to spend some time tonight trying to get this resolved, if not hopefully I can return it.
04-03-2012, 05:08 PM   #10
Brooke Meyer
Guest
Fixed Pentax 540 that wouldn't zoom
Tonight, found one my Pentax 540's stuck at "16mm", would not Zoom. Read this old thread, cycled the Diffuser panel a few times with no change. Powered down flash and tapped the flash head a few times with a plastic handled screwdriver. Turned on flash and it worked! Must have been a stuck or dirty switch. This old thread led the way.
af-540fgz, tripod
DA* 16-50 stuck - won't zoom or focus amoringello Pentax SLR Lens Discussion 23 12-13-2016 11:05 AM
Stuck zoom head on Metz 48 EricT Flashes, Lighting, and Studio 10 04-20-2013 12:52 AM
540FGZ Stuck Pin Revisited Raylon Pentax Camera and Field Accessories 13 07-03-2010 01:41 PM
Stuck zoom ring photogwannabe Pentax SLR Lens Discussion 5 06-08-2009 03:31 PM
Auto zoom on AF-540FGZ question dws1117 Pentax Camera and Field Accessories 2 12-15-2008 09:53 AM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
