Originally posted by gsrokmix Hi,
I know there have been a lot of tripod discussion on this & other forums. I need a good tripod to mount my K20 on. The biggest lens I have at the moment is a Vivitar Series 1 70-210. I also have a Vivitar 285HV flash. I am 5'9" tall.
I will be using this tripod outdoors a lot. I would like to be able to point it straight down at the ground. I would also like to be able to shoot very low to the ground with it. I would be willing to use an aluminum tripod if it cuts the cost considerably. I would like to keep the price to around $300 for the tripod, head, & plate. Am I asking the impossible? I have read great things about Gitzo & Manfrotto from various people. The problem is that there are too many of these to choose from. I am nowhere near a good camera store so I'm trying to narrow the field a little before I have to drive a couple of hours to see one of these in person.
I would really appreciate any thoughts and opinions of specific setups you are using.
Thanks!
George
G'day George,
I would approach this a little differently given that you say you are going to have drive some distance/time to get to a store. (and I believe you are doing the right thing in wanting to 'road test' it for yourself).
My wife & I have just gone through the process....but we had a wide choice to look at.
My advice is to ring the stores you plan on visiting and see what they carry in stock and then do your homework on those makes/models, rather than do a lot of leg work to only discover that what you like is not stocked.
You will need something that will hold min 5-6 kg. Heads is a very personal choice.
Ash's comments are on the money, I have the 055 but am eyeing off a Slik CF 814.
Pay particular attention to the folded height if you think the tripod may travel by air for fitting in luggage.
Good luck
Grant
