Originally posted by thomascdk
I bought an Eye-Fi SD-card. Bad idea. I guess this goes for K-20s as well. The card doesn't work with my GX-20.
"I just checked with the engineering team about this and they advised me that Samsung camera does not work very well with our Eye-Fi card they have made the recommendation that you return the Eye-Fi card or use it in another camera."
Don't buy...
Either things have changed since this post or you haven't properly set the card up.
I wasn't going to buy an Eye-Fi after reading this post, because I wanted to use it with a GX-20, then I read elsewhere that they worked with the *istDs which I till have. So I decided to give it go and bought the 4GB Home version.
Setup was far from easy the supplied software wouldn't complete and tried to blame Firefox. I downloaded the alternative Eye-Fi Center application which completed the registration and installation without any problems. It also updated the cards firmware. Then came a lot of messing entering the MAC code of the card into my router.
After that it was simple I just put the card into the *istD, clicked the shutter and then I saw the picture unfold as it downloaded on the screen. Fast because of the jpeg size. I tried and few shots and it worked OK, then I possibly went out of range and 3 shots I took hadn't downloaded. I switched the camera off/on and was surprised to see the last 3 shots download very quickly.
Then I switched the card over to the GX-20, took a shot and that downloaded straight away. I took about another 20 shots and they all downloaded.. no problems.
The 10MB Jpegs from the GX-20 take about 30 secs to download, which isn't really a problem, well worth it for setting white balance etc.
The only pain is that you have to enter your email addy and password every time you want to use it. Absolute nonsense because it only goes as far as my computer. I hope they fix that with an update. Getting around the Eye-Fi site is also a problem, I had to go through forums to find out where to DL software.
Software
linky
I've set up an old version of ACDSee (v3.1) to keep a watch on the DL folder for new files and pop-up an almost full screen preview as soon as they complete. I think Lightroom can do similar.
shimbo
Next
