11-18-2009, 10:24 PM   #1
Another split focusing screen Question
Im sure someone can answer this for me.I want to buy a katzeye split focusing screen for my K10D. I do a lot of early morning long exposure shots as well as a lot of ND filter work using a ND 400. Hour would the split focus screen go under these conditions.Especially as the ND filters are pretty dark to start with.
11-19-2009, 05:37 AM   #2
Let's see. It is 7:30am, raining and hazy.
The split screen, ( ME SUPER ), in my DS is not blacked out at 5.6. I just put the ND4 on it, darkest I have,and it still was not blacking out at 5.6.
A 10 stop ND is bound to black out the prism. Unless it is pointed at or close to the sun.
11-19-2009, 06:01 AM   #3
Lowell Goudge's Avatar
in the case here I doubt af would work either as it is almost pitch black.
you might be better off with the stock screen in this case because at least you can (maybe) see something to focus manually with
11-19-2009, 06:22 AM   #4
Wheatfield's Avatar
Why not focus first, and then put the ND filter on? The Katz-Eye will make your manual focusing life easier, but it won't work miracles if you cut down the light hitting it so much that you can't see it.
11-19-2009, 06:32 AM   #5
Just did a little calculating. It's 5 stops from f8 to f256. There is no way you will focus looking through the filter. The exposure times will be huge.
11-20-2009, 02:17 AM   #6
Thanks for that. I should have realises that as I normally cant see through the ND 400 anyway. Putting the filter on after focusing would be the way to go.
11-20-2009, 04:14 AM   #7
raider's Avatar
I have a 9 stop Hoya filter which I use from time to time, mostly pairing with my DA14. AF while not fast, is still possible with the filter.
lot, screen, split, split focusing screen, tripod
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
Seeking advice on focusing screen (split screen) for K200D Ari Freund Pentax DSLR Discussion 8 07-31-2009 03:00 AM
For Sale - Sold: K100d and 18-55mm kit lens + split focusing screen installed + glass screen pr vanchaz2002 Sold Items 1 07-24-2008 07:09 AM
Split Image Focusing Screen Question. Sprags Pentax Camera and Field Accessories 3 05-16-2008 10:41 AM
All times are GMT -7. The time now is 10:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
