"Intervalometer" is the technical name for that timer.
Originally posted by Dangermouse Aha! Right, an update:
The timer works if you hold the shutter button down. Presumably the trigger switch would make this easier, I might have a go at making one. It looks like a standard stereo-type jack plug connection so I can easily buy one of them, a push switch, a box and a length of speaker cable. The temptation to use a big red button is exceedingly strong!
Even better would be to have a switch that can be either push to make or latching, as that'd cover both single shot and timer modes.
Incidentally, you can make a cable release for Pentax DSLRs with some Fig. 8 stereo cable and a headphone plug. Don't know if the connections are the same, but, if they are, well then, you've just got yourself a cable that's doubly useful.
Quote: I posted this thread in the Accessories section. This morning, I find that it has been moved to the SLRs. Then I find it's back in the Accessories. Now, I don't mind the moving. But what I do object to is when I get a snotty personal message "as a reminder of the rules" when I originally posted it in the right place!
Welcome to Pentax Forums. Thanks to the dearth of forums, sub-forums and mods (who never seem to talk to each other, and are always convinced they're right, hence your thread getting bounced around like a baby in a cement mixer,) it's a bureaucracy of Soviet proportions...and the consequences for getting it wrong are nearly as grim. Did you get any "points" deducted from you?
Believe it or not, having a mod disagreeing with your choice of location (and I'm sure 99% of forum members would think a Winder is an accessory, but that's not important,) is your own fault, and if you do it often enough, you will be booted from the forum (funnily enough, there're no means to vote mods out of their position or give them citations.)
In short, it's joke. Russian roulette. It's why you're not allowed to post about Chinon or Ricoh cameras in the Film SLR forum (even though every sees them as being practically Pentax) and why it's a crapshoot to post about charging someone for a print - because it could belong in the Pro forum, the Post Processing forum, or Everything Else (when all else fails, or if a mod feels left out of the Great Thread Monte.)
Remember, at Pentax Forums, you're too stupid to know what your post is about!
