11-22-2009, 09:09 PM   #1
MJB DIGITAL's Avatar
Optical Trigger, Trailing Curtain Synch
I never have been able to get that to work, so I thought I would ask...have you gotten it to work?
I use (3) 540FGZ's
Thanks.
11-22-2009, 09:32 PM   #2
Canada_Rockies's Avatar
I wish I had my k10 back. I could work this out for you. I think you have to use one of your 540's as the controller. I don't think it can be done with the built in flash as the controller/master.
11-22-2009, 09:33 PM   #3
Yeah I wish I had mine back too! They are both in Arizona getting brain surgery...
8(
11-22-2009, 10:26 PM   #4
Damn Brit
Guest
This is a better fit in Camera and Studio Accessories.
11-23-2009, 12:48 PM   #5
hoanpham's Avatar
If this is any help:
I am using 2 sigmas ef 530 super. they should be similar to any pentax flash supporting optical wireless protocol. I have to attach one sigma on the camera, then manually adjust the flash setting to trailing curtain sync. The other sigma is set to slave mode. I tried to detach the flash but what ever I do, no trailing curtain sync than the one I described. Very annoying.
11-23-2009, 11:35 PM   #6
Gary thanks for the move, I wasn't really sure where to put it and thought it was a technique.
Anyway...
I shoot high speed synch all the time. Literally, my flashes all remain in high speed synch. At the park in harsh sun, it comes in handy. At the reception it doesnt really matter....
What I have to do is just make sure that ALL of the flashes involved in the exposure are set to highspeed synch.
I tried the same thing with trailing curtain synch and....no go
11-24-2009, 01:17 AM   #7
hoanpham's Avatar
Trailing curtain does have their use. I also tried radio trigger on hotshoe, but got only first curtain sync. One more thing even more annoying after my taste: trailing curtain is disabled in the menu choice when a manual focus lens is attached to the body.
This feature should be easy when I put everything in manual. As I see it, this limitation is on the firmware.
Hotshoe sync should enable trailing curtain too. Easiest way is calculating the time backward: if the sync speed is 1/200 then trailing curtain should start 1/200 before the curtain ends. Should work for hotshoe/x-sync and with any regular flash.
As a professional feature: Sync time start can be set at any speed before the curtain ends to give complete control timing (see pocket wizard's). That means not only trailing/second curtain, but also "any curtain".
Sorry long reply,
Please someone post an enhancement request on this.
11-24-2009, 01:29 AM   #8
res3567's Avatar
QuoteOriginally posted by Canada_Rockies Quote
What happened to it?
tripod
K7 and Flash on trailing curtain problem mymage Flashes, Lighting, and Studio 6 08-15-2010 03:17 AM
Trailing Curtain w/ Manual Flash? Venturi Flashes, Lighting, and Studio 11 05-19-2009 11:29 PM
Wireless trailing curtain synch? MJB DIGITAL Pentax Camera and Field Accessories 2 07-04-2008 09:10 AM
Trailing curtain flash problem -- help! tdb Pentax DSLR Discussion 2 05-14-2008 03:06 PM
Trailing Curtain, my new favourite tool! blwnhr Post Your Photos! 11 02-10-2008 05:04 PM
All times are GMT -7. The time now is 07:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
