Veteran Member Join Date: Oct 2006 Location: Chicago suburb, IL, USA |
I've decided that the largest lens I'll practically use is the FA*300/2.8 with TCs -- just can't deal with the size and weight of the really big glass on a regular basis. For me, the Wimberley Sidekick is the ideal solution for a number of reasons.
I like dealing with Wimberley. The CS people that I've talked to are very knowledgeable, and for a pre-gimbal user, there are a lot of details to sort out, especially like what plates are needed to balance specific lens/camera combos. Wimberley CS had answers for at least some Pentax-related questions, where some of the other mfgs seem to have little experience with Pentax (not an unreasonable situation, considering Pentax's market share, especially with sports/wildlife shooters, but this was a nice surprise for me -- and I also like the idea of supporting US companies in this economy, if possible). After the first e-mail communication with them, I knew I'd like dealing with this company.
Wimberley has a free test ride program where you can order and use the head, plates, and any other accessories you might fancy, and return anything that doesn't suit your needs, no ?s asked. (You do have to pay for the return shipping). They hold charging you for the order until you've decided what you're going to keep, and your warranty period starts only when you've finalized what you're keeping -- then you still have a return/exchange period that starts at this time. . . Outstanding CS and company policies count for something IMO.
. . .Add the availability of accessories, like the flash bracket, and you can have a pretty sophisticated gimbal system.
The Sidekick attaches to a ballhead via an Arca Swiss style clamp, and has another A/S clamp to attach your lens to on the gimbal. This has a number of advantages:
If you want to change lenses (to something smaller) and want to use the tripod, you just dismount the Sidekick (as easy as removing a camera from the QR clamp) and use the ballhead as normal. With a full gimbal, you must dismount the head, then mount a ballhead for use (and you'd have to carry the ballhead separately). I always have a plate attached to each of my bodies anyway. . .
The Sidekick only weighs @ 1 lb, and is MUCH more compact than a full gimbal, and thus a lot easier to carry and store -- I use an orphan tube sock -- not elegant by effective.
With the Sidekick, you are not as limited in the vertical angles that you can shoot. The ballhead allows you to easily tilt the Sidekick back so you can shoot straight up which is not possible with any of the full gimbals, unless you use different leg angles and lengths to tilt the center column (and setting that up isn't easy with a heavy cam/lens combo attached, unless you're using a tripod with a tiltable center column. . . even then, it's always a lot easier to adjust the ballhead. You do need to be careful when using the Sidekick like this as the weight can get offset quite a bit -- proper leg orientation can become very important.
There are some caveats:
You need to get an A/S style plate that will allow the cam/lens to balance (but you'd have to do that with any gimbal).
You need a quality ballhead with good panning action, even while supporting an offset weight. It also has to have an A/S style clamp (or be capable of being converted to one), and the ball has to lock solidly.
If the lenses that you can envision owning weigh significantly over 7-8 lbs, you should probably consider a full gimbal -- this isn't from experience, but rather from reading testimonials. For physically really large lenses or if you plan to use multiple lenses with a large variance in size, the extra adjust-ability of the full Wimberley Head would be an asset, but with the lenses I have (Tamron, Sigma, and Pentax 300/2.8, and occasionally the Tokina 150-500/5.6 SD) the Sidekick is fine. Anything smaller, I usually tend to shoot handheld.
I use a Manfrotto 468 MG RC2 as my ballhead base, and Wimberley had a conversion clamp that fits perfectly. This ballhead works great with the Sidekick as the panning action is very smooth, not effected by the offset weight, and the hydraulic ball lock mechanism is very solid, not requiring a whole lot of force on the knob. The Wimberley clamps and plates are very good -- no lever style clamps, but they do allow top mounting the plates and have optional safety stops that should be compatible with just about any clamp.
I know I was completely lost when I was trying to determine the best gimbal for my use. There's not a whole lot of info about them that's aimed at the gimbal newbie. Hopefully I've added some info rather than confusing the issue further.
. . . and no, I'm not connected to Wimberley in any way except for being a very satisfied customer. . .
Scott
