Originally posted by dugrant153 That’s the reason I wanted to go belt and lens changer-style pods as well. Changing lenses can be time consuming and a huge juggle otherwise, and I’d have to be doing it on the ground or finding another flat surface to place it on. My first solution to that is shooting with two cameras with different focal lengths (currently 30mm and 55mm) so I simply don’t have to switch lenses. The other solution is this belt system (so I can change lenses on the fly for both cameras) and a way to hold my cameras without tangling on me. Using the R-strap right now and it’s very very nice.
That sounds all very sensible. Probably goes very nicely with the R-strap, too, maybe with a holster for a second body with lens or whatever.
I do OK with as wieldy-sized a bag as can carry everything, (it can be a bit tight, but with cameras out, I can get at things) ...I've considered adding a bit of a belt thing to this, either to bring a longer lens at the last minute, or whatever else,maybe to work out ofmore-easily while I'm at it.
Quote: Agreed. It is good to test out whether the lens pouches fit the individual lenses. Do you folks usually size a pod for a lens with a lens hood on or off? I find that my current pods are perfect for when the lens hood is off, but when they are on they extend out a little and cannot be zippered up.
On, with anything, I'd say. You don't want to be fussing with hoods on a shoot. In general, I only reverse a hood if it's the only way the lens will come along at all.
If you have any big lenses with long hoods that stow that you want to use, though, it seems ThinkTank at least actually makes some cases that expand,so you can kind of do both.
Quote: Very true. Not to mention the balance of weight on your body (which is also relative to physical size). I find I am way more balanced when crouching or standing when the weight of my lenses and backup camera are on my hips rather than the small of my back. I wear my 7MDH “messenger-style” which makes it more comfortable as the weight is on my shoulder and my chest (WAY more comfortable) but with a heavy bag, I can become quite top heavy.
The nice thing about messengerey/appropriate shoulder bags is that you can wear them that way, or off the other shoulder and still have them in essentially the same place, switching if you become fatigued.
A lot of the cleverer solutions out there these days seem to tend to be organized around the M.O of fewer, bulkier lenses and bodies and stuff: I'm kind of stuck in the 80's to some degree, here. (But that's part of why I like Pentax.
) Because I'm still splitting my carry kit between Pentax and old Canon for film, it often adds up to carrying a lot of extra/redundant glass in a medium-sized bag, (I've got a Lowepro 190, about the size of a Nova 4.) but it could as easily be a nice selection of primes and a bigger piece or two for one system. Say, some flash, a longer lens or whatnot.
I somewhat lost my train of thought while writing this yesterday, so, no real conclusion, just maybe helpful ideas.
