12-20-2009, 11:39 AM   #1
RRS plate options for K200D?
Hello. I just bought a mint condition used K200D for my wife for Christmas, so we can share lenses and I can see my K10D again.
For tripod work my K10D and ballhead use a Really Right Stuff plate and clamp. Are there any Arca-style plates for the K200D? I haven't been able to find anything so far.
RRS seems to make a "generic camera" plate. Anyone used this with a K200D?
Thanks in advance.
12-20-2009, 03:52 PM   #2
wlachan's Avatar
The old generic fit B21 should do. Since I haven't the K200D, I am uncertain. The current B24 doesn't fit the K-m/K2000 because the rear anti-twist sits too high.
12-21-2009, 01:01 PM   #3
Eaglerapids's Avatar
When I bought my stuff from RRS I called them because I had a few questions. Their staff are very knowledgeable and I'm sure could answer your question. They are great people to do business with.
12-22-2009, 04:13 AM   #4
Kirk makes a plate for the istDS. It might be close enough to be a good option. I suppose the RRS option would be the plate for the istD. Markins has a plate for the K100D, a plate for the istD, and a plate for the istDS/istDL
Thank you
Russell
12-22-2009, 09:05 AM   #5
I have an Acratech plate (Arca-style) for my K20 ($39) that I moved to the K100 when I picked up an L bracket (from Kirk). It fits fine and works perfectly.
The folks at RRS would know for sure.
Quick Release Camera Plates*::*Acratech
12-31-2009, 11:51 AM   #6
Thanks for all the replies.
I have the K10/K20 plate from RRS, and it definitely doesn't fit the K200D. But I've emailed RRS to ask which of their generic plates will work best. I'll post their response in case anyone else comes looking for the info.
Cheers,
Jos
QuoteOriginally posted by interested_observer Quote
01-04-2010, 11:57 AM   #7
Really Right Stuff replied to my question with the following:
"the B21 plate is now discontinued and was replaced by our BP-CS plate. This plate typically fits most film cameras."
Anyone happen to know how well this will fit a K200D? I am concerned about the height of the rear lip.
Cheers,
Jos
11-30-2010, 01:26 PM   #8
sewebster's Avatar
Sorry to bump an old thread, but I'd be interested in knowing which plate I can put on my K200D to use with an RRS clamp as well...
12-04-2010, 06:01 AM   #9
Banned
Are you using the lever clamp or a standard screw clamp on your head?
Acratech has the Quick Release Plate 2138
This plate, with some minor modifications will fit the K200. I find that the rear edge is a bit high and pushes against the camera housing. It took me less than 5 minutes with a small file to round the edge and it fits fine now. You cannot even see the place where I filed when it is on the camera.
B&H sells these plates usually.
I use a Kirk BH 1 ball head and it works fine, but if you are using a lever clamp from RRS, it may not work. They recommend only their plates for the lever clamp system if I recall.
12-04-2010, 11:44 AM   #10
sewebster's Avatar
I dont actually have an RRS clamp at the moment, but thought they looked nice. But thanks for the plate recommendation... could be quite useful for any of the compatible head options.
12-28-2010, 01:49 AM   #11
I can confirm that the BP-CS plate from RRS fits the K200D perfectly.
The best way to use it is mounting it "backwards" - positioning the raised lip at the front edge of the camera, under the lens mount, not the rear. Mounting it this way keeps the plate clear of the battery compartment hatch, and works with the raised lip better. The only drawback is that it places the plate's strap lug on the left side, which would be a problem if you want to use it with a wrist strap.
12-28-2010, 09:17 AM   #12
sewebster's Avatar
QuoteOriginally posted by Bogartist Quote
Cool, thanks for reporting back!
k10d, k200d, plate, rrs, tripod
For Sale - Sold: K10D kit,grip,Katzeye,RRS plate (US/CAN) MSM Sold Items 5 07-05-2010 01:43 PM
POLL: Who would want an RRS L-plate made for the K10/20D + grip? soccerjoe5 Pentax Camera and Field Accessories 32 04-14-2010 09:47 AM
All times are GMT -7. The time now is 11:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
