Originally posted by Ash It will depend on the focal length you're using (I'm guessing 28mm or so), but the shutter speed of 1/30 sounds right in all the auto modes. Switching to X mode gives you the flash-sync speed and M mode will allow any speed you want.
The 540 flash with K10D (even the K20D) is notorious for underexposing flashed images. I'd suggest boosting FEC to +0.7 or 1.0 and consider the metering mode on the camera when shooting a scene.
Also consider how far away your subject is and whether it exceeds the flash's ability to illuminate your subject. You may need to bump up ISO in this regard.
Hope you work it out.
Yes, was using the FA 20mm mostly...then switched to the DA18-250 used mostly at the wide end. So it "locks" in to 1/30 sec for wide angle shots? You'd think that would be in the manual somewhere...maybe I missed. it.
Ended up shooting in manual mode with the camera to get the exposure I wanted.
Thanks for the info!
