Originally posted by raz-0 class 6 SDHC is not as fast as 150x in and SD card.
SDHC classes:
Class 2 = 2 MB/s
Class 4 = 4 MB/s
Class 6 = 6 MB/s
With regular SD, it is something times x: 20x, 40x, 150x, etc. That x is 150 kilobytes per second, the same as a single spin CD-ROM drive. So 150x should be about 22 MB per second.
Originally posted by pixelpruner Thanks for the comments. I still don't understand though if there is a difference between SD and SDHC in terms of performance. I know SD uses FAT16 file system and SDHC uses FAT32, but does anyone have any idea what this means in real money, except the allowance to go up to 32gb in capacity?
I don't see how Class 6 SDHC could be that much slower than 150x SD when they are such a similar price. I'm thinking I might just buy the fastest 2gb card in every brand I can so if one breaks I won't loose confidence in the others!
Thanks
se above for the answer. Add on that an SD reader will not read an SDHC card unless it is also an SDHC reader. SDHC is different technology than SD.
Not to mention that although there are 4GB SD cards, the SD standard only goes up to 2gb. what can read and write to them is hit or miss.
My personal take is buy multiple cheap 150x 2gb sd cards. THey work fast in all my card readers, my camera likes them, and if any one goes bad, it takes a smaller chunk of your pictures with it (especially in RAW).
Buying transcend 150x from a reputable vendor seems to be the way to go.
