Originally posted by creampuff Even Manfrotto doesn't make good enough heads imo.
I'll disagree a bit here, but only specifically -- generally, the statement is accurate, though, IMO. My main head is a Wimberley clamp modified 468MG (used to have an RC2 QR), and this is a
very good head. Magnesium cinstruction, separate lock, tension, and pan controls and a hydraulic lock system that locks the ball dead solid with very little effort. It only weighs about 1 lb, and with the added security of the Arca Swiss compatible Wimberley clamp, this light and relatively compact head is all I need for lenses up to the 300/2.8 class by itself, and it makes a very good base for my Sidekick as the panning base works very well with the offset load of the gimbal attachment.
I used to like Amvonas because they were dirt cheap -- mine cost $13-17 for the small and medium sized A S compatible units, but after some use, the design faults of these made them pretty much unusable. They look good, but are junk inside.
I recently played with a Vanguard SBH-250 head at a local camera store, and was impressed. Separate lock, tension, and pan controls, A S clamp, two spirit levels. It seems to be very well made and smooth in operation. They had it priced at $89 USD, so I imagine it could be found for less online. I'd buy one. . .
Scott
