Originally posted by tallison I have a Bower SFD926P and a Pentax af240z. I would like to use the Bower in p-ttl mode with an off camera cable on a stand triggering the af240z in auto mode as a fill flash.
The Bower has a built in optical slave. Just use the AF240Z on the camera in A mode and it will trigger the Bower for you. No cables, but also no P-TTL.
I remember a post a long time ago with someone saying the delay optical slaves didn't work, so that is why I am suggesting doing something else. I can't remember the post or the poster. I'm not even sure it was here, it might have been at DPR.
Do you have the K20D or K-7 with the sync port? You could use that for your setup as well. P-TTL cable and remote Bower, PC sync cord and pc sync hot shoe with the AF240Z.
The other option would be a
Pentax P-TTL adapter F,
Pentax P5 cord, and another P-TTL adapter F to connect the Bower. Then on the Pentax adapter F on the camera, as it is also a hot shoe, add a PC sync hot shoe and cable, and another PC sync hot shoe on the other end for the AF240Z.
You could also go with the
Pentax P-TTL adapter FG,
a Pentax P5 cord, and a
P-TTL adapter F and just use the on board flash as fill for a completely P-TTL solution.
You probably don't want to buy the
"off camera adapter F" as it is a lot more expensive than the "adapter F" for some strange reason. You can spend
$3 on ebay to get a remote flash stand with a tripod mount, save money, and have a more useful set up.
If you already have a P-TTL cable, it isn't a Pentax cable, and you don't own the K20D or K-7, you could open the cable up and add a PC port to it to make this all work.
Thank you
Russell
